mfdoom7 Posted August 2, 2019 Report Posted August 2, 2019 Will a Bass face DB1.4 feed x15 or i need better amp to push that sub. Amplifier stats: Genuine Useable RMS Power, 4Ohm Bridge (Watts), < 1%THD, 14v 1120x1 Genuine Useable RMS Power, 2Ohm Bridge (Watts), < 1%THD, 14v 1870x1 Genuine Useable RMS Power, 1Ohm Bridge (Watts), < 1%THD, 14v 2730x1
tdsa23 Posted August 3, 2019 Report Posted August 3, 2019 I never heard of the brand but if the amp does its power you should be good. XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
mfdoom7 Posted August 3, 2019 Author Report Posted August 3, 2019 9 hours ago, tdsa23 said: I never heard of the brand but if the amp does its power you should be good. right now i have EDGE EDB15D2X-E7 wich claims to have 1100w rms but it bottoms out or gets hot and smelly when jamming long time 15min or more lissening to decaf. so sub is holding back what my amp can do. electrical is fine never go below 13v with 120A alt and 72ah battery, big 3 is done.
CstrokerV Posted August 3, 2019 Report Posted August 3, 2019 Bottoming out and getting hot isn’t necessary the sub not handling the power usually more that the box is wrong and amp is clipping my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
mfdoom7 Posted August 4, 2019 Author Report Posted August 4, 2019 21 hours ago, CstrokerV said: Bottoming out and getting hot isn’t necessary the sub not handling the power usually more that the box is wrong and amp is clipping Does not clip ive checked with scope to be sure box is about 3cuft net so cant be that big for 15 tuned to 30hz
slowfkncar Posted August 4, 2019 Report Posted August 4, 2019 Could be playing too far under tuning, easy to do with a decaf playlist, a more efficient box might also help. 3cf sounds small for 30hz with an x15.
image91 Posted August 7, 2019 Report Posted August 7, 2019 Putting "2700wrms" on an "1100wrms" rated subwoofer is going to have downsides. That being said, as tdsa23 mentioned, if the amp does rated power or anything around 2000-2500wrms, you should be fine.
mfdoom7 Posted August 7, 2019 Author Report Posted August 7, 2019 8 hours ago, image91 said: Putting "2700wrms" on an "1100wrms" rated subwoofer is going to have downsides. That being said, as tdsa23 mentioned, if the amp does rated power or anything around 2000-2500wrms, you should be fine. just want to know if i can get cheap upgrade by just changing sub and maybe build bigger box for x15. in theory sundown should be louder vs my current EDB15D2X-E7 here is a video about what that single EDGE 15" can do with 1k rms amp
