Help with set screw size please.
I have dual inputs for mine, but no guarantee they are the same size... I would contact SHCA directly or get a combo pack of set screws and hope one works
Or if you have the other input then get measurements from it and order up a couple spares
if SHCA can't help you could try going to lowes or another local hardware store if you have one and see if you can find a bolt that has the same threads. once you know the threads you can probably buy the correct size from a lot of places. I would contact SHCA first though.
had the same need for an arc audio amp     went to my local ace and they had a set screw drawer   $.99 each     I sent arc audio $20 twice and never did get the right ones
ace hardware                               I walked in and was out in 10 minutes
