Dragonsyph Posted March 19, 2020 Report Posted March 19, 2020 I have some cheap wire right now that i think is fake 8 gauge wire, was gonna order some new wire form down4sound, Certified Basshead 8G OFCSPK Wire (Blue&Clear). My Salt 4 amp is OTW finally and was wondering if said wire above will do fine for 5-6k watts? Or do i need to buy some 4 gauge wire? Use a calculator online it it says if i use 8g ill loose around 600 watts? Not sure if thats true or not. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA
kookz Posted March 19, 2020 Report Posted March 19, 2020 8 gauge OFC will be more than sufficient. My salt 8k shipped today too ill be using 8 gauge on that Goodluck 😎 Walled Police Interceptor Four 15s 160s
Jessica Posted March 19, 2020 Report Posted March 19, 2020 8ga is fine, unless you are doing a 25ft run or something. besides, depending on what suib or subs your are using you are splitting that power over multiple wires Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
AaronT Posted March 20, 2020 Report Posted March 20, 2020 If you can fit 4g in terminals both in subs and amps, why not use it.
ehall8702 Posted March 20, 2020 Report Posted March 20, 2020 I have 8ga ofc wired to my 15s about to hook to my taramps 8k, would have went bigger if subs would accept bigger , seems the md8000.1 would accept like 6gauge , the shca ofc 8 gauge is a bit smaller than terminal openings. But like said above , unless u are running a LONG run from amp to subs, 8 is plenty big enuff. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
