Need Port Help--rusty We Need Ur Help Too
49W X 17T X 20D
those are my box demensions, i need port in the middle tuned to around 37 hz, there was a website i was told about but cant remember the name
any help will be great, thanks
Edited by loganberry
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Dimensions, would draw up a box design but this computer won't run CAD or SketchUp at all.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
49W X 17T X 20D
are those external or internal dimensions? also whats the displacement of your subs? any bracing?
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
i believe its external, but i could be wrong, yes, LOTS of all thread, lol
10" 12" 15" 18"
Mounting Depth 6.25" 6.75" 8" 9"
Mounting Hole Diameter 9.25" 11" 14" 16.75"
Motor Width 7.75" 7.75" 7.75" 7.75"
Weight 31.5lbs 32.5lbs 33lbs 35.5lbs
VC Diameter 3" 3" 3" 3"
Magnet Weight 28.5lbs 28.5lbs 28.5lbs 28.5lbs
Power Handling RMS/Peak 1000/2000 1000/2000 1000/2000 1000/2000
Impedance D 2ohm D 2ohm D 2ohm D 2ohm
Sd 314.00 cm² 494.00 cm² 791.00 cm² 1159.00 cm²
Vas 27.40 L 66.60 L 160.00 L 260.90 L
Cms 1.99e-04 m/N 1.95e-04 m/N 1.83e-04 m/N 1.39e-04 m/N
Mms 115.70 g 173.08 g 211.60 g 218.61 g
Fs 33.2 Hz 27.4 Hz 25.6 Hz 28.9 Hz
Bl 16.15 N/A 16.15 N/A 16.15 N/A 16.15 N/A
Re 3.60 ohm 3.60 ohm 3.60 ohm 3.60 ohm
Le 4.02 mH 4.02 mH 4.02 mH 4.02 mH
Qms 5.15 5.13 6.07 6.55
Qes 0.43 0.42 0.47 0.70
Qts 0.40 0.39 0.44 0.63
Xmax 23.5 mm 23.5 mm 23.5 mm 23.5 mm
Sensitivity 85.50 dB 87.0 dB 89.4 dB 91.4 dB
Suggested Sealed N/A N/A N/A N/A
Suggested Ported 1³ ft 1.5³ ft 3³ ft 5.75³ ft
Suggested SPL Ported 1.25³ ft 2³ ft 4³ ft 8³ ft
idk what u mean about displacement
but there are the specs and here is the site
http://dcsoundlab.com/specs.html
My F-150 Build
15.5" high (top to bottom), 6" wide and 18" deep.
Are you building a new box for the LV4's?
same box, different front and adding strength
but that will only give me less then 2 inches from end of the port from rear of the box
My F-150 Build
  • Who's Online   1 Member, 0 Anonymous, 1117 Guests (See full list)
