When making a slot ported box, does the sub have to be infront of port wall?
Hey i just want to know, when making a slot ported box with L bend, does the 2nd port wall that runs the width of the box, have to be behind the sub? Kind of hard to explain. Pls look at photo attached. The box im building has a very short port length so once it bends its only 2 or 3 inches... So my sub will not be infront of any wall. Is this OK or will it cause problems?
The top pic is what my box is going to look like.  Is that ok?  Or should it always look like the bottom pic where the port wall is behind the sub magnet?
Thanks
The only thing is the subwoofer has to have at least the same amount of breathing room from the wall it’s facing as the diameter of the hole on the bottom of the magnet (the pole vent). So if the pole vent is 1” in diameter, the back of that subwoofer magnet has to have 1” of room behind it from any wall, be it a port wall or regular wall or bottom or whatever.
:guido:
There is plenty of room in between pole vent and port wall or back of enclosure wall. So as long as there is sufficient space (1 to 2 inches i find is the bare minimum) the port wall doesnt have to be behind the magnet.
So, as long as there is 1 to 2 inches clearance, the top drawing will work.
yessir, either pic will work just fine
Get as much room as possible between pile vent and port wall as possible, had 3" between my hds2.108s and the dust caps actually dented in still....was 4 8s on 3k, and only subs with port wall behind them sucked caps in....didn't make same mistake with my new box for sure.
Theres plenty of room like 4 inches or so maybe more. I was just curious if the sub had to have the port wall behind it or not in order for the box to work properly. Cuz this design i made the L bend is mad small and its almost not even an L its like an I 🤣
Nah that works, have built many boxes with a straight slot port. Actually more efficient that way, be happy URS worked out that way.everytime a port bends or turns you lose port velocity and affect the subs efficiency ( atleast that's what I understand from the MANY things I have read and researched and from all the boxes I have built).
I had no idea about if it was ok to do a non bending slot port, it looked weird when i designed it so i needed verification it would work before i got it built. Nice to know its more efficient this way. I learned something new today. Yay.
  • Who's Online   1 Member, 0 Anonymous, 1173 Guests (See full list)
