CodyDaGoat Posted May 30, 2020 Report Share Posted May 30, 2020 preferably under 1.2k. Want to clamp between 3 and 4k after rise Link to comment Share on other sites More sharing options...
CodyDaGoat Posted June 2, 2020 Author Report Share Posted June 2, 2020 Still looking Link to comment Share on other sites More sharing options...
AaronT Posted June 2, 2020 Report Share Posted June 2, 2020 You'll need to basically double what you expect after rise, so 6-8k Link to comment Share on other sites More sharing options...
SkinnyFeets Posted June 2, 2020 Report Share Posted June 2, 2020 Sundown SALT-4, they run just a little above $1200. Orion's HCCAs would be a good option as well. Link to comment Share on other sites More sharing options...
CodyDaGoat Posted June 4, 2020 Author Report Share Posted June 4, 2020 Would a DC Audio 7.5k be too much if wired to 1ohm before rise or can the subs handle it? Link to comment Share on other sites More sharing options...
SkinnyFeets Posted June 4, 2020 Report Share Posted June 4, 2020 Even after rise, you'd be pushing your luck. Link to comment Share on other sites More sharing options...
CodyDaGoat Posted June 4, 2020 Author Report Share Posted June 4, 2020 I was told these can handle a lot more power than what they are rated. Figure 2 ohms after rise 4400 watts? I heard the X15s could handle up to 3.5k each Link to comment Share on other sites More sharing options...
CstrokerV Posted June 4, 2020 Report Share Posted June 4, 2020 9 minutes ago, CodyDaGoat said: I was told these can handle a lot more power than what they are rated. Figure 2 ohms after rise 4400 watts? I heard the X15s could handle up to 3.5k each Its installer dependent all because others did doesn’t mean you’ll be able to... dc 5k or a sundown sfb 8000 or even a 3000 per woofer more then enough for your subs my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 5, 2020 Report Share Posted June 5, 2020 2 hours ago, CstrokerV said: Its installer dependent all because others did doesn’t mean you’ll be able to... dc 5k or a sundown sfb 8000 or even a 3000 per woofer more then enough for your subs This “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 5, 2020 Report Share Posted June 5, 2020 Or a sundown scv-6000d but that’s about $1700 but it would be ideal for them subwoofers. There’s only one place selling them right now. https://www.woofersetc.com/scv-6000d-sundown-audio-monoblock-6000w-rms-amplifier.html “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
