SQ Setup
Daddy_
I'm looking to do a SQ setup but with a bit of output. Car will be a 2019 Mazda CX5 with the Bose system. Will be running a single amp to run the whole system. Amp will be a JL Audio VXI 1000/5. Fronts will be ran active either Focal K2 series or JL C5's. The sub will be built into the spare tire well. I was thinking of going a single W7. I can either do a 8w7 ported or 10w7 sealed. I only have around 500 to 600RMS to play with on the sub channel. I want to be able to hit every low and high note but not sound boomy. An example of the sound I am going for is you know when you get a nice high end sound bar from Samsung, Bose, Sonos and the bass is just right. That is what I am trying to achieve and wouldnt mind a bit more output.
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
I don't know about the components, but if I had to choose between the subs, I'd go 10" sealed.
At least that's my opinion
Well Im trying to get the loudest but flattest response. Could anyone model these up for me?
 12 "Image Dynamics IDQ in 2 ft3 tuned to 30 hertz on 600RMS
12" JL W6v3 in 1.75-2ft3 ( which ever is flatter) tuned to 30 hertz on 600RMS
12" Audiofrog GB 1.5-1.75 Tuned to 32 hertz on 600RMS
12" Image Dynamics 2.5 tuned to 30 hertz on 750RMS
Lastly If I can get similar results with a slim sub I might as well go with the JL 12 TW3 in 1ft3 ported tuned to 32 hertz on 600RMS
Just curious, have you looked into Sundown/SSA ?
Sundown Audio E-10 V.3 - 500w RMS - $140
Sundown Audio SA-10 - 750w RMS - $218
SSA Demon 10" - 550w RMS - $156
SSA FBL 8" - 650w RMS - $170
I know you want it tuned to a specific hz w/ either ported/sealed.. But I just wanted to help by throwing some other options at you.
Good luck man!
  • 3 weeks later...
Good luck man!
[b]Excellent choice on the Demon.[/b]
  Hertz subs rock at sq then fi Q and ssd with ht option don’t think they are taken mg orders for them at the moment though  ... but you can have alot of output and then turn down the sub when you want not as much output for more of a balance sound
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
