Fusing Question
Uhhh...
30a x 6 = 180a
Correct.
Me=incorrect.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
i really dont like being an internet smartass but with this long answer you gave, it might have been easier to do this
100a=bad, 160 or larger=good.
less space, question answered, no aggravation :D
Well since that would be a bad answer I didn't write it
160amp on 4awg over 8ft would be bad.
Sounds like you still haven't used the search button or google.
Just because Im a little nice today.
http://www.the12volt.com/wiring/recwirsz.asp
This is real simple man, your amp requires 180 amps of fuseing.
It sounds like it has built in fuseing.
If its the only amp you are running I recommend putting a 200 amp fuse at the battery.
Me personally I would use a 225 amp ANL if they make them, you might only find 250 amp ANLs.
So if my power wire was comming straight from the battery to the amp I would use either a 200 amp or a 250 amp ANL fuse at the battery.
You should be covered as far as current drops go.
If your amp does not have built in fusing I would put a 225 or 250 amp ANL fuse at the battery then I would put the closest thing to a 180 amp fuse as close to the amp as possible.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
200-250 amp anl on fucking 4awg...??????????
How about NO FUSE, cause you'd be using the god damn wire at that point.
He should have atleast a 200 amp fuse up by the battery if his amp has 180 amps worth of fusing on it and its got a 10 foot to 17 foot run of power wire. The fuse WILL BLOW if it gets shorted out.
I did not pay attention to what size wire he already has. For me anything that has the ability to pull that much current I automatically use 1/0 guage.
I do recommend upgradeing to 1/0 gauge.
Look at darvex for high quaility power wire.
in short:
My local shop sells 1/0 gauge for $8.00 a foot.
Darvex the same 1/0 seems to average $4.25 a foot and less.for the same stuff.
in short:
yeah i am definatley going with 1/0ga but right now my truck was loaded with 4ga and i spent a ton of money upgrading everything else so the switch will be easy. any of you guys use a 0/1g to 4g reducer terminal? the guy at the local shop suggested one, but isnt that defeating the purpose of upgrading in the first place? makes me wonder why memphis only used 4g terminals for this amp even though it's pulling all that power?
hell the newer Rockford T1500-1bd uses a 200 amp fuse and it only accepts 4 ga. the reducer would/will work fine.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1817 Guests (See full list)
