benz280se Posted May 14, 2008 Report Share Posted May 14, 2008 (edited) hey folks i just recently installed my memphis mch1300, and it's a really good sounding amp. i'm a little confused about what outboard fuse to run. it uses 6 30a fuses and i have a 100a fuse between the amp and battery. is the 100a fuse big enough or do i need more? spec sheet 5-Channel MClass Series Amplifier Class-AB / Class-D Hybrid Amplifier Compact Aluminum Chassis with Custon Black Pearl Finish Gold Plated RCA Connectors Full MOSFET Design Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4) Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5) 4-Way Protection Circuitry Platinum Finish Wire Connections Accepts 4 Gauge Power and Ground Wire Optional Wired Remote Gain Control RMS Power Ratings: 75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms 115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms 1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!) Adjustable Input Sensitivity: 200mV - 4V Dimensions: 25.81" L x 7.6" W x 2.4" H 1-year Sonic Electronix warranty Amplifier Specifications: Amplifier Class Channels 1-4: A/B, Channel 5: D Number of Channels 5 RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan. RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan. RMS Power (1 ohm) 1100 watts x 1 channel for the 5th channel (Channels 1-4 Not Stable) Bridged RMS Power 230 watts x 2 channels Peak Power Output N/A Minimum Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5) Minimum Impedance Bridged 4 ohms THD at Rated RMS Power 0.03% Speaker Level Inputs No Preamp Outputs No Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP) High-Pass Crossover Frequency 40 - 6000 Hz Low-Pass Crossover Frequency Channels 1-4: 40-6000Hz and Channel 5: 50-250Hz Subsonic Filter 20 - 50 Hz Signal-to-Noise Ratio 95 dB Channel Separation N/A Bass Boost N/A Bass/Gain Remote Optional (Memphis 16-MCRG required and sold separately) Fan Cooled No Fuse Rating 30A x 6 Edited May 15, 2008 by benz280se Quote Link to comment Share on other sites More sharing options...
benz280se Posted May 16, 2008 Author Report Share Posted May 16, 2008 (edited) hey folks i just recently installed my memphis mch1300, and it's a really good sounding amp. i'm a little confused about what outboard fuse to run. it uses 6 30a fuses and i have a 100a fuse between the amp and battery. is the 100a fuse big enough or do i need more? spec sheet 5-Channel MClass Series Amplifier Class-AB / Class-D Hybrid Amplifier Compact Aluminum Chassis with Custon Black Pearl Finish Gold Plated RCA Connectors Full MOSFET Design Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4) Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5) 4-Way Protection Circuitry Platinum Finish Wire Connections Accepts 4 Gauge Power and Ground Wire Optional Wired Remote Gain Control RMS Power Ratings: 75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms 115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms 1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!) Adjustable Input Sensitivity: 200mV - 4V Dimensions: 25.81" L x 7.6" W x 2.4" H 1-year Sonic Electronix warranty Amplifier Specifications: Amplifier Class Channels 1-4: A/B, Channel 5: D Number of Channels 5 RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan. RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan. RMS Power (1 ohm) 1100 watts x 1 channel for the 5th channel (Channels 1-4 Not Stable) Bridged RMS Power 230 watts x 2 channels Peak Power Output N/A Minimum Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5) Minimum Impedance Bridged 4 ohms THD at Rated RMS Power 0.03% Speaker Level Inputs No Preamp Outputs No Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP) High-Pass Crossover Frequency 40 - 6000 Hz Low-Pass Crossover Frequency Channels 1-4: 40-6000Hz and Channel 5: 50-250Hz Subsonic Filter 20 - 50 Hz Signal-to-Noise Ratio 95 dB Channel Separation N/A Bass Boost N/A Bass/Gain Remote Optional (Memphis 16-MCRG required and sold separately) Fan Cooled No Fuse Rating 30A x 6 can somebody please just take two seconds and say if the 100 amp fuse is big enough or should i go up? Edited May 16, 2008 by benz280se Quote Link to comment Share on other sites More sharing options...
EricM9104 Posted May 16, 2008 Report Share Posted May 16, 2008 100a fuse is too small. The amp fuse rating total is 160a. Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
Mosin Posted May 16, 2008 Report Share Posted May 16, 2008 100a fuse is too small.The amp fuse rating total is 160a. X2 Indeed Quote Derp. Link to comment Share on other sites More sharing options...
Kicker Guy Posted May 16, 2008 Report Share Posted May 16, 2008 What size wire are you using? That is what determines the fuse size for the power wire. Quote Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz Link to comment Share on other sites More sharing options...
Ray Posted May 16, 2008 Report Share Posted May 16, 2008 See you wont get a quick answer cause you didn't even bother using a search and look for yourself. Dont be lazy, do some homework. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
benz280se Posted May 16, 2008 Author Report Share Posted May 16, 2008 thanks for your replies right now i am using 4 gauge wire since i had it already in the vehicle, and the terminals on the amp accept 4 gauge. when i get more money and time i'll add 0 gauge, but in the meantime, i will get a 160a fuse then. thank you guys a lot. Quote Link to comment Share on other sites More sharing options...
benz280se Posted May 16, 2008 Author Report Share Posted May 16, 2008 See you wont get a quick answer cause you didn't even bother using a search and look for yourself.Dont be lazy, do some homework. i really dont like being an internet smartass but with this long answer you gave, it might have been easier to do this 100a=bad, 160 or larger=good. less space, question answered, no aggravation Quote Link to comment Share on other sites More sharing options...
Derrick824 Posted May 16, 2008 Report Share Posted May 16, 2008 Uhhh... 30a x 6 = 180a Quote Link to comment Share on other sites More sharing options...
banginAltima Posted May 16, 2008 Report Share Posted May 16, 2008 Uhhh...30a x 6 = 180a You know, I was thinking that number wasn't right... Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs Link to comment Share on other sites More sharing options...
