http://www.the12volt.com/ohm/ohmslaw.asp
alright here we go.
in the hypothetical calculation of power we resort to the laws created by Ohm (dont remember his first name)
my question is simple
in equations involving impedance ® wut number would i mathematically enter into the equation?
for example when calculating amps i divide volts (E) by impedance ®
I=E/R
so i want to find amps i know that my system is running 70 volts (theoretical situation) and my impedance is 1 ohm. so does that mean that my amps are also 70? if its 2 ohms does it mean i have 35 amps now? wut about .5 ohm do i now have 140 amps?
it seems logical but i want to be sure im doing the calculations correctly
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
yes you are right
DC.jpgDC POWER
x2 and i havent a first clue as to what you are even looking to learn from that lol...
why not just get a clamp meeter and volt meeter and do real power tests (for a given freq)
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
well see id rather do the math because i love math and im plannin on bein an electrical engineer so im gonna need to know these things
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
im taking a class to be a technician right now and thats one of the basics you will see over and over and then about 6000 more times. :wacko:
DC.jpgDC POWER
alright here we go.
I=E/R
opps didnt read the question
u r correct
Edited by decafcappucino
Word.
