slybu Posted April 7, 2021 Report Posted April 7, 2021 I dealt with regular blade fuses and the MAXi type blade fuses and found there to be a fair difference favouring branded fuses from the likes of littelfuse, bussmann, and MTa. but with fuses like ANL, and mini anl i cant seem to find those made by reputable manufacturers. how do generic brand ANL fuses fair like in this link: https://www.ebay.co.uk/itm/ANL-Gold-Plated-Fuse-Fuses-Car-Audio-50A-80A-100A-150A-200A-250A-300A-350A-500A/133303852057 do they blow as they are supposed to or do they just get hot and melt the fuse holder etc?
Dafaseles Posted April 7, 2021 Report Posted April 7, 2021 I don't know if there's a huge difference because I've never used cheap ANL fuses, but I would assume that with most anything else, there's a huge difference. I look at it this way, those fuses are keeping your equipment safe and your vehicle from burning to the ground. I wouldn't cheap out on those. Tons of reputable manufacturers of ANL fuses. SMD, Sky High Car Audio, GP Car Audio.... just to name a few 2011 Chevy Silverado under construction My build log here. Check it out!
slybu Posted April 7, 2021 Author Report Posted April 7, 2021 Problem is most of the brands like sky high, knu, rockford etc all have those fuses made in china and their name painted on it. None of those fuses come with actual spec documents like the ones you get from littelfuse, mta and bussmann. Will hunt around more though and see what i can find.
Dafaseles Posted April 7, 2021 Report Posted April 7, 2021 You're probably right. But just because it's made in China doesn't make it bad. But I do get your point. On a side note, if you can find ceramic ANL fuses, those handle heat better than the plastic ones. If you find anything, let us know 2011 Chevy Silverado under construction My build log here. Check it out!
slybu Posted April 10, 2021 Author Report Posted April 10, 2021 Yes i did spot some ceramic fuses at a reputable electronics provider here in the uk called RS Components. Expensive though.
slybu Posted August 28, 2021 Author Report Posted August 28, 2021 At what point would someone switch from a mini anl to full size anl fuse?
Dafaseles Posted August 28, 2021 Report Posted August 28, 2021 17 minutes ago, slybu said: At what point would someone switch from a mini anl to full size anl fuse? There's not really much of a difference between the 2 except the physical size 2011 Chevy Silverado under construction My build log here. Check it out!
CstrokerV Posted August 29, 2021 Report Posted August 29, 2021 Smd has ceramic fuses… seen them somewhere else also … I just bought a bag of cheap plastic ones they have been working fine my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Never Enough Bass Posted August 29, 2021 Report Posted August 29, 2021 Xs power has some good fuses to 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
slybu Posted July 17, 2022 Author Report Posted July 17, 2022 Iv found a supplier of good quality anl fuses. They are Siba branded and come with datasheet information. https://uk.rs-online.com/web/p/car-fuses/1611834 Will stick to these fuses from now on. mine arrived today, so just to add this fuse doesnt have a plastic housing, its ceramic.
