Would changing the port size (NOT port length) affect the tuning frequency?
Mason Denk
I'm working on a Skar Audio ZVX 18, and I have all other specs down. KickerU is giving me a square port, instead of a rectangular one. The square port is 8.86in by 8.86. Is there a way I could change this port to a rectangular one, without changing the tuning frequency? Tuning is 30hz, as requested by owner. Thanks to all who answer, and have a good rest of your day!
-Mason
You can change the shape without effecting tuning. As long as you keep the desired amount of square inches of port opening. The length of the port mostly determines the tuning frequencies
So does width and height
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
You're right, it does. I'm sorry
He's gonna have to compensate somewhere to make it right if he goes higher he's either gonna have to be not as wide or not as long his choice
06 Charger
Pioneer double din
Xs power d3400
Just keep the area the same … times the 2 together then play with the dimensions till you get the same as the 2 that was times together and keep the length just for an example of mine was 4X4 that’s 16 so I could do a 8x2 and it would keep the length the same
This isn't the same and I hope it works but I made my design 2in deeper so I made my port 2in longer
06 Charger
Pioneer double din
Xs power d3400
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
