Sundown SA8 box
Daddy_
Let me start by saying I'm going to putting this in a Acura RDX SUV and gonna run 500rms. I'm looking for more sound quality than output. I want a nice sq ported box for a single SA8v3. I'm want less peaky but a nice smoother response. I'm not experert but I'm guessing around .60 to .75 net ft3 tuned around 33hertz?  Could someone come up with a box for 20wide 10 high 10 deep.
Also as I said before I'm looking for nice sound quality. Would I be better off going with a sundown  8" SD4 sealed or even a JL 8w3v3?
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
If you want output but you don't want to be peaky you go with a higher diameter sub and do sealed, box would still be 1 cubic feet or less, just a little taller, you can use your own 12W7 in a 1.375 cubic feet net box or pick a 12" that works in a smaller box. The SA8 will still be peaky in a 0.6 net box and will give very little output in sealed.
I don't have that set up anymore I sold everything now I'm starting fresh in a new car.
So go ported on a single SA8v3. Could you give me a outline of cutout sheet. I prefer 33 Hertz
If I go sealed I'll probably go with the SD4
How would this box do. Could you tweak it and make it more sound quality oriented?
https://subbox.pro/en/b/dVFV5ZFeJ
Or this one but prefer first one
https://subbox.pro/en/b/Sp2ufH06v
That sub would work great sealed and that’s kinda what your talking about that you want for sound. I’ve ran SA’s in a sealed box they sound great.
 How much airspace did you give them
 You will need like 12 square inches of port area for your box, anyways since you are in a SUV now you may not even hear that single 8" at all sealed or ported, given the vehicle size I would be thinking of a single 1K 15" sub sealed at least to accomplish what you want.
So these boxes seeing work for a single ported SA8? The plan is to keep one for now and then later add another 8"
Could you design me a ported box for a single SA8v3 tuned to 33 Hertz. 20wide 10high 10deep. The less space you can use the better
I ran SA 10’s  in a sealed box , 3-10’s 1 box all separate chambers at probably  .65 cubes each before displacement.
Two 8s have similar cone area as a single 12", not much of a point on owning them unless they are used in an under seat enclosure like you see in ext cabs and such, anyways here are two enclosure, one small and one average sized, the small is kind of choked and difficult to build so I recommend the average sized one, neither can meet 10x20x10 size but close:
Figures are just assembly guides.
Small:
Average sized:
  • Who's Online   2 Members, 0 Anonymous, 1508 Guests (See full list)
