Some photos of the new SMD mini anl fuse / distro blocks. From 2 spots up to 8 spots (4 to 16 spots on the ground/distro bars) They have 8ga inputs/outputs to keep the blocks very small…but i designed a really nice single and double input 8ga to 2ga/4ga adapters for those that want to run larger wires. Available in several colors! Copper coming soon as well. Visit www.wccaraudio.com if you have any interest in one of these jewels 💎 💎 We have SHCA mini anl fuses from 50 to 175a in stock to go with them 😎
  • Like (+1 Rep) 3
Follow my Tweet (Twitter)
Nice!
I see these pairing well with the conductor from Sparked.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
New 4/2ga and also 1/0 inputs! The configurations will be (3) 8ga (the prong side) to (3) 1/0 inputs with on on the right, one on the left and one in the middle.  Use one, both or all!  Basically you can now come in from the side.  Also available in (3) 8ga (the prong side) to (3) 4/2 gauge (also left, right and middle).  The options will be many!  You can use these dual and triple input adapters on either side to double or triple any fuse value! I was really busy today I didn't have a lot of time to play with these, but here is a few pics I took before I left today.
Coming in from either side with a giant SHCA 1/0 OFC wire.  ALL BLOCKS fit right next to every other block.  You can put as many as you can get on it with good clearance!
these blocks can be configured for use with any combo of 12ga, 10ga, 8ga, 6ga 4ga, 2ga and 1/0 depending on the adapter.
More photo's later when I get a chance to take them for the website.  The new adapters are not ready for a few more days, but hopefully be ready by Monday or Tuesday.
Imagine the size of a system you can run off these small blocks with just a few adapters.
some optional extension lids in case you use adapter blocks and want more coverage. It will be easy to get to all the set screws without removing the lid!
  • meade916 changed the title to New SMD Mini ANL Fuse and ground/distro blocks and adapters
  • Who's Online   0 Members, 0 Anonymous, 1057 Guests (See full list)
