mufuqua Posted November 29, 2023 Report Share Posted November 29, 2023 (edited) I know I can strap two compatible amps together for double the power, so two 2000w 1-ohm stable amps should be 4000w 2-ohm, right? So could I wire the D1 sub to a 2-ohm load to the strapped amps at the 2-ohm load, or should I just buy the D2 ver. and run the amps to a single voice coil, or like wire the D2 sub to a 2ohm load. I'm using two CT-2000.1d amps and a single SunDown zv6 12 D1. Should I buy new parts or could I hook them up? I don't wanna blow this expensive gear, I can return them if I've made any mistakes in my calculations so. Edited November 29, 2023 by mufuqua Quote Link to comment Share on other sites More sharing options...
Joe X Posted November 29, 2023 Report Share Posted November 29, 2023 You can absolutely run the strapped amps to coils in series sub is just that if you play a continuous sinewave of 4000W+ watts the sub may not like it a lot, Quote Link to comment Share on other sites More sharing options...
mufuqua Posted November 30, 2023 Author Report Share Posted November 30, 2023 So does that also mean technically you could have the strapped amps run with the 2 ohms 4000w on two d2 dvc 2 subs as well. So like if I wanted to run 2 subs to the 2 ohm strapped instead of my single d1 dvc 1 sub, two d2 dvc 2 subs could work? Quote Link to comment Share on other sites More sharing options...
Joe X Posted December 1, 2023 Report Share Posted December 1, 2023 To the strapped pair you can use any final load of 2 ohm including 2 D2 subs. Or even run one sub to each amp at 1 ohm final. Quote Link to comment Share on other sites More sharing options...
