ok... before i got my system i figured that i would need a bigger alt cuz my stock alt was only puttin out 60A at idle. so i go to autozone and pick up one of there 140A alts(this is before i knew the difference between idle and max :P )... get the system installed and this alt still isnt enough. been dealing with that til i get a bigger alt. but i figured that the alt will put out 70A at idle so i just keep the volumn down unless im on the freeway so i can keep the engine at a high rpm... so im drivin on the freeway last night music on full blast and im doin about 75 on the freeway(drove for about 30 min) well all of a sudden my damned lights start to dim on every tiny little bass note and my subs are nowhere near as loud as they were. :unsure: so i turn the radio off and drive for another 30 minutes back home. make it back home, turn the car off, but it will not start back up... :angry:
now that thirty minute drive back home should have been enough to give the battery at least a little bit of a charge. WTF.
so i get a jump and the car starts like normal.
now is it just me or isnt an alt supposed to charge the batt when there is no other load on it. why didnt mine charge back up?
the amp is a 1606d with two 15" L5s
sorry so lengthy
maybe you burned the alternator and it wont charge..take it to autozone they can check it for you for free
well when i got the car jump started i let it run for about ten minutes at idle. then i turned it off and cranked it back up about three or four times and everything seemed to be fine. could it be the battery
Either your alt isn't charging like it should or you battery won't hold a charge like it should.
Take it to autozone and have them test the alt if the alt is okay then you'll need to replace your battery....and if you do replace your battery get a deep cycle.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
been lookin into getting a deep cycle batt... took a look on kinetics site and they suggested the hc 1400. would i do better just replacing my starting battery or adding the deep cycle as a secondary :unsure:
  • Who's Online   0 Members, 0 Anonymous, 4203 Guests (See full list)
