I am about to do the big three upgrade. I got all the supply I need: 6' 1/0awg wire, fuse holder, 200amp fuse, and ring terminals. From what i know is that I need to run wire from alt to batt(pos), from batt(neg) to chassy, and from batt(neg) to engine block. But I am not sure if this is a good spot for grounding on the engine block. I pointed it out on my pics below. Will this be a good spot for grounding?
There is an open hole here where I can easily run a ground to, but is this a good spot?
Edited by honda
My Soundz:
'06 ACCoRD
Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE
Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU)
CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ
TWO Diamond D6 12" DVC 4ohm
Coming soon upgrades:
Batts
dynamat trunk kit
If you really wanted too, Im sure you could, but it wouldnt be the best ground by looking at the plenum.
Id try to shoot for a better ground, something that bolts to the block like a alternator bracket or something of that nature.
is that really 1/0 gauge cable?..it looks kinda thin dnt u think?..dats wut i think but idk....i might be wrong...
Second. I don't know how good that ground is going through the aluminum intake and with the gaskets and bla bla bla.
There has got to be a better spot like audiofanatics said that is closer to the alt.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
This would be easy and accessible, take off the bolt (should be 14mm) sand around for good connection and your good to go:
i was gonna say dat 2...lol
thats the shock tower he was asking about running a ground to the engine. i would run a ground to the engine block . how about the bolt on the alt bracket should work good.
Yeah you're right, i already have a spot for grounding it to the car/chassy. I heard about grounding to the bak of the alt but with my car, it looks difficult cuz its really tight around that area.
The wire is 1/0awg, by Tsunami. It is the same wire I have running to the trunk. Are they a pretty good brand when it comes to installation accessories?
Edited by honda
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
tsunami is good stuff. kinda pricey , but good quality. Also, yeah, try for a bolt on the engine block it self. Stay away from a exhaust manifold bolt, only cause of the excess heat, but keep lookin, maybe get on the ground and have a look around from the bottom. I actually followed my factory ground wire down and from under the FJ I saw where they bolted the ground right to the side of the block. Prolly a similar set up somewhere on your car...
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
  • Who's Online   0 Members, 0 Anonymous, 4261 Guests (See full list)
