How much does power compare with cone area. Say if i had a BL 18 on 1000wRMS compared to 4 BL10's on 4000wRMS....
Previous: 1988 Nissan Patrol
Rockford T800.4
Rockford T1 15 (sealed)
Rockford 6.5 Components
Current: 1997 Jeep Wrangler
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
Alpine 9886 Headunit
RF P300.2
RF P500-1bd
2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz
4x Hertz HCX130's
Current comment...
Satisfied for the moment, focusing on performance upgrades
that again is a hard question to answer because you are adding another variable. but if it was a bl 18 vs 4 bl 10s on the same amount of power the 4 10s should be louder because of cone area.
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
  • 2 months later...
IT all depend on the enclosures, electrical, type of sub, music, amp and etc.
  • 4 weeks later...
where are you coming up with your cone area?
6 8"s = 301 sq. inches of cone area
2 12"s = 226 sq. inches of cone area
neither will be a groundpounder though, unless they were DD 1508's on 5kw IMO.
2001 Chevy S10 ex. cab
-Pioneer Premier 490ib
-Sundown Audio SAX-100.4 / Autotek MM4000.1
-Dayton PA165's (x4) / Power Acoustik NX-5 bullet tweets
-2 15" Audioque HD3's walled(9 cubes net @ 38hz, 160 sq. in. port)
-Big 3, Optima Red Top, Batcap 2000's (x2), All 2/0 welding cable
  • 2 months later...
I have seen a lot of people talk about cone area of woofers and make massive mistakes.
You average 12 inch woofer has not only its radaiting area (Sd) from its cone but part (usually 1/4 - 1/2) its surround as well.
It is best to check with the manufactuer as they will give you a more accurate figure.
Most 12's have between 480 cm2 and 530 cm2 of (Sd) cone area that is:
480/2.5 =192 sq ins
or
530/2.5 or 212 sq ins.
Then (Sd) cone area x excursion reached (peak) will give you Vd which is total driver displacement (i.e. air compressed).
It is not just cone area that makes output, the size and type of box will adjust the efficency bandwidth (i.e. where in the frequency range it is efficent) of the design.
Larger boxes favour the bottom end where as smaller boxes favour the upper end. With a ported enclosure you are also getting output around the tuning frequnecy of the vent this acts like extra displacement (i.e. like more cone area).
Of course the driver will be designed with a bandwidth in mind as well some tend to favor low tuning where as other tend to favour higher tunings it is all down to the design of the woofer.
Adding extra power is good up to a point as eventally the driver is saturated with heat and gets hot, the coil(s) impedence rises and thus your amps produce less power (less load) and output does not increase, this is driver themal compression.
Then there are cabin losses/gains to be considerd, higher up in the bass range cabin resonation aids output (often 45hz plus) DBDrag users use this to assist there score. Low bass (45hz and under) flexes the cabin and you loose output, a strong cabin will not flex and allow maximim low bass to be produced.
So lots of cone is good as long as other factors: enclosure size/strength, power supply and cabin is correct also.
My saying: "A boom a day keeps the hearing away."
  • 3 weeks later...
480/2.5 =192 sq ins
or
damn, that was a serious run down :blink:
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Thanks!
The key element is understanding that no one part is the most important on its own, all the factors come into play.
Damn
Well said man.
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Truck is down and out for a while
Myspace
YOUTUBE
My Build
480/2.5 =192 sq ins
or
Thats some weird numbers there man
I worked in the manufacturing field for about 5 years, and how the manufacturer calculates cone area, is middle of surround to middle of surround on the complete opposite side
Dividing the SD in sq CM seems like it would be correct dividing by 2.5, but that is way to large
I just picked up a 12" cone in the garage, and measured it, and it was 10" across
using PIE
5x5x3.14 is about 78sq inches of usable cone area
Which that is common on 12"s about 150-175sq inches on 15"s depending if its narrow surround, or fat surround
There is a pinned topic on this, and that topic is correct
If a manufacturer is saying they have a 12" with 192 - 212sq inches of cone area, well, that is BS
I can believe in cubic area the cone are plus depth of cone, but thats now how cone area is measured
If you are correct, and I' am wrong, then every tline that sounded so damn good, and everyone who built t lines, and the whole transmission line theory are completely wrong
