Clocksta Posted August 7, 2008 Author Report Share Posted August 7, 2008 so after i install, if i dim a little bit, would a better battery most likely fix it? Quote Link to comment Share on other sites More sharing options...
DUBIE Posted August 7, 2008 Report Share Posted August 7, 2008 so after i install, if i dim a little bit, would a better battery most likely fix it? adding extra battery(s) would help..it will only be for a while thoug..it would always be better upgrading a bigger alt.. Quote Link to comment Share on other sites More sharing options...
Clocksta Posted August 7, 2008 Author Report Share Posted August 7, 2008 oo ok Quote Link to comment Share on other sites More sharing options...
wL<3bass Posted August 7, 2008 Report Share Posted August 7, 2008 (edited) adding extra battery(s) would help..it will only be for a while thoug..it would always be better upgrading a bigger alt.. You need a good battery and a good alt not one or the other but both....and the closer you put the secondary battery to the amp the better off you would be. Edited August 7, 2008 by wL<3bass Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
EricM9104 Posted August 7, 2008 Report Share Posted August 7, 2008 WRONG, some cars hella dim with a measly 400 watts and lights run on a un-regulated power supply, hence dimming from a slight voltage drop. Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
MECHMAN Posted August 7, 2008 Report Share Posted August 7, 2008 and lights run on a un-regulated power supply, hence dimming from a slight voltage drop. A 500 watt ampplifier usually draws between 30-40 amps at full volume. Most all vehicles are built with only as much alternator as they require, (although it varies from vehicle to vehicle) In order to eliminate voltage drop, and to be able to play the system indefinitely without eventually running down the battery(s), it would be good engineering to increase the charging systems capability by 30-40 amps. You won't have huge problems, but the headlights might dim a little, and your system might not get as loud as it could be with more available current. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Clocksta Posted August 7, 2008 Author Report Share Posted August 7, 2008 well i just figured it shouldnt be to bad with only 500watts and it only being for some highs/mids, no subs yet so yeah Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted August 8, 2008 Report Share Posted August 8, 2008 well i just figured it shouldnt be to bad with only 500watts and it only being for some highs/mids, no subs yet so yeah You probably won't have any dimming running just mids and highs, they just don't draw nearly as much power as subs do. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
DUBIE Posted August 8, 2008 Report Share Posted August 8, 2008 You probably won't have any dimming running just mids and highs, they just don't draw nearly as much power as subs do. yea dats true...subs usually take more power.. Quote Link to comment Share on other sites More sharing options...
missinglink Posted August 9, 2008 Report Share Posted August 9, 2008 The sub amps will draw more power of course mainly on the lower 30hertz tunning range. You need alot more solid power and storage to hold the low notes!!! X2 mids and highs they should be fine, duel batteries are a good idea for most audio applications anyway. MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander... Link to comment Share on other sites More sharing options...
