alright im tyin to get my trunk to stop rattling, there are big holes all over in the trunk lid and i was wondering if expanda foam could be used to help deadin it? there are no subs in the trunk just amp?
also will this trap heat more? i am tryin to get my trunk to not get as hot since my car is black, will expanda foam help with this or no? thanks
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
you can use it, just dont use too much at one time because it can warp the lid. it expands a lot, so be careful. and its actually insulation, so it will in a sense, insulate your trunk a little bit.
Yep..you can use it...just have to make sure that it has room to expand..I have seen it do some real damage!!
His amp produces heat so it will trap some of that.
true true, but not near as bad as ambient heat using the trunk as an oven. definitely not a bad idea for fans tho
Old man Mikes van??
It's going to add weight to the lid and act as a deadener as well. In my old car I had the lid full of expanding foam and 3 sheets of butyl deadener, and the lid didn't like to stay open on it's own.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
  • Who's Online   0 Members, 0 Anonymous, 2792 Guests (See full list)
