well what would be the best way to run my wiring you think?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
what do you mean to run your wiring? where to fuse it? where to run it to the back? how to hook 2 amps up?
i'll answer for him, he needs to know all of the above
nothing wrong with the 3000DB amp.... Id buy one
But if you have more money to spend on a amp, then there are better options
Ok...I didn't see, but has anyone noticed or said anything about the topic name being incorrect???? It's sposed to be an 8, not a 9. LoL.
well after my doin my taxes are my choices are 2 pa3000db,i loved my last one,or a xx colossus,but i dont know which one yet,the pa did 2300rms at 1 ohm i ran mine at .75.never had a problem with it,for the same price theres the xx colossus which does 1600x2 at 1 ohm,which will be ran at .75 ohm again
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
the reason you will have no issues that low of an impediance is because of Impediance rise.
.75 is practicly  1ohm with imp rise it will be well above 1ohm  my van saw a rise of 2.5 ohms @ 39hz
get the pa3000db's  youll end up with more power with them then a Collosus.  I likethe Colossus better as a amp but more power and probably more reliable at the ohm rating would be 2 pa's
