I was just curious about something and thought I would post it here and see if anyone could explain it to me, I was just curious why if say I have a sub that can take 2000w and an amp putting out at least that, why do I put 1/0 gauge wire to the batt and amp but like 8 gauge to the sub? How is my 2k watts getting to the sub through such small wire? Just curious :D
Voltage, current, and length of wire all play rolls.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
power inputs on the amp have to sustain minor voltage (12-15v) and a hell of alot of amps (current). but the speaker wire only has to carry higher voltages and not so much current.
The power wire is on dc voltage, while the speaker wire is on ac voltage. Ac voltage can use a smaller wires at same voltage of power wire
Don't think that is true.
Its all about the input voltage being around 13 so to get 2 kwatts you going to be 150 plus amps. Now on the output side of your amp it is ac and also a higher voltage around 63v(if running at 2 ohms) so you only have 31 amps of current going through your wire.
Also you have a much longer distance from your bat to your amp then your amp to your sub. The wire has a resistance through it naturally so if you have a long run and need allot of current your going to have a big power lead.
Cliff
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
High voltage can pass through thin gauge wires. High amperage cannot.
think about this: have you ever seen the tiny gauge you're house electrical outlets are? they're pretty thin, but still are able to carry a total output of roughly 1500-2000 watts. That's because @ 120volts, it only requires 15amps to equal 1800watts. When using only 12volts, it takes 150amps to produce 1800 watts. as you may already know, volts x amps = power(watts)
Amps - 2x t1500-1bd
Subs - 2x hdc315's(copper d2's)
Deck - 1940's Amplitude Modulation radio
ZING!
My YouTube Videos
  • Who's Online   0 Members, 0 Anonymous, 4332 Guests (See full list)
