I was just curious about something and thought I would post it here and see if anyone could explain it to me, I was just curious why if say I have a sub that can take 2000w and an amp putting out at least that, why do I put 1/0 gauge wire to the batt and amp but like 8 gauge to the sub? How is my 2k watts getting to the sub through such small wire? Just curious :D
Voltage, current, and length of wire all play rolls.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
The power wire is on dc voltage, while the speaker wire is on ac voltage. Ac voltage can use a smaller wires at same voltage of power wire
Don't think that is true.
Its all about the input voltage being around 13 so to get 2 kwatts you going to be 150 plus amps. Now on the output side of your amp it is ac and also a higher voltage around 63v(if running at 2 ohms) so you only have 31 amps of current going through your wire.
Also you have a much longer distance from your bat to your amp then your amp to your sub. The wire has a resistance through it naturally so if you have a long run and need allot of current your going to have a big power lead.
Cliff
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
High voltage can pass through thin gauge wires. High amperage cannot.
think about this: have you ever seen the tiny gauge you're house electrical outlets are? they're pretty thin, but still are able to carry a total output of roughly 1500-2000 watts. That's because @ 120volts, it only requires 15amps to equal 1800watts. When using only 12volts, it takes 150amps to produce 1800 watts. as you may already know, volts x amps = power(watts)
Amps - 2x t1500-1bd
Subs - 2x hdc315's(copper d2's)
Deck - 1940's Amplitude Modulation radio
ZING!
My YouTube Videos
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
