osixfrontier Posted September 17, 2008 Report Posted September 17, 2008 http://vids.myspace.com/index.cfm?fuseacti...ideoID=42988873 http://vids.myspace.com/index.cfm?fuseacti...ideoID=42988448 before i go the alt in it did a 147.2 at 38 hz with voltage drop to low 12's so ill meter again this weekend with 1 more batt and the ho alt....that is sealed at the dash..... Quote 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
eaglescorpio1 Posted September 17, 2008 Report Posted September 17, 2008 can't knock it man, movin tons of air. Keep it up. P.S. You need more caulk!!!! J/K Quote Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!!
osixfrontier Posted September 17, 2008 Author Report Posted September 17, 2008 yeah they are sx's.......i had 2 12's before sx's as well and my side window poped out and broke....so i got a nother one but it was from an 88 so the screws didnt line up...so i used caulking but forgot to check if it was clear before i applied it....then my windshiled started to leak water....so again i caulke it...i dont care though its my work car...still gets 30mpg.... Quote 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
doug118 Posted September 17, 2008 Report Posted September 17, 2008 you need to change your pcv valve to stop that idle surge Quote 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
osixfrontier Posted September 17, 2008 Author Report Posted September 17, 2008 actually its the iac thanks for your concern....but im gonna replace that motor with a better one after the up coming comps....one this weekend and another in novenber.. Quote 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
Nightshade Posted September 17, 2008 Report Posted September 17, 2008 Looks good. It might get louder with the woofers all the way in the front of the box near the front two seats instead of all the way in the back. I'm guessing that you have the port on the box firing back? If so I would say that you will gain if you do move the woofers closer to the front. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
07sOnAtA sp.ed Posted September 17, 2008 Report Posted September 17, 2008 impressive, looks loud as hell man. good job Quote CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
