http://vids.myspace.com/index.cfm?fuseacti...ideoID=42988873
http://vids.myspace.com/index.cfm?fuseacti...ideoID=42988448
before i go the alt in it did a 147.2 at 38 hz with voltage drop to low 12's so ill meter again this weekend with 1 more batt and the ho alt....that is sealed at the dash.....
99 4runner
walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar
orion hcca 8000.1d
8 Polk audio mm 691 6x9
2 2000x4 hifonics
320 amp singer alt
3 g31
1 baby seat 1 booster seat and daily driven!
yeah they are sx's.......i had 2 12's before sx's as well and my side window poped out and broke....so i got a nother one but it was from an 88 so the screws didnt line up...so i used caulking but forgot to check if it was clear before i applied it....then my windshiled started to leak water....so again i caulke it...i dont care though its my work car...still gets 30mpg....
99 4runner
orion hcca 8000.1d
2 2000x4 hifonics
320 amp singer alt
3 g31
actually its the iac thanks for your concern....but im gonna replace that motor with a better one after the up coming comps....one this weekend and another in novenber..
99 4runner
orion hcca 8000.1d
2 2000x4 hifonics
320 amp singer alt
3 g31
Looks good. It might get louder with the woofers all the way in the front of the box near the front two seats instead of all the way in the back. I'm guessing that you have the port on the box firing back? If so I would say that you will gain if you do move the woofers closer to the front.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
  • Who's Online   1 Member, 0 Anonymous, 1206 Guests (See full list)
