I really hope you arent serious.....why would you have a 300amp alt and 200amp alt and 1 battery.............your gonna need like 5 hc2400s atleast.
ok I'll sell the 200 I allready have and buy 3 300's and 4 batts
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Why? Just get more batteries....you aren't gonna run a single batt with multiple alts....the 300 amp and a 200 amp should do fine regardless your gonna need serveral batteries.....D3100s or HC2400s
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Join the Big league and run HC3800's
Now those are Powerhouses!
70lbs a battery x3 is why
500lb box x1
70lb subs x2
30lb amp? x2
well thats good the biggest system I've done is 2500 watts so I don't want to fry 3g's in amplifiers
Edited by wenn_du_weinst
If I remember rite the original MOJO amps weren't really the greatest for SQ. I don't know about the new ones but I would defiently go with the Rockford T40001BD.
I just feel its a better amp all the way across the board if you know what I mean.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
500lb box x1
70lb subs x2
30lb amp? x2
well u better give up if you dont want battery weight. or just suck it up so that you wont blow your amps.
I have the Mojo its a very powerful amp once you get the voltage up. My voltage was sitting at 13.3 & the amp would get hot fast i even burnt the MOSFETS twice but now i have the MLA module & my voltage sits no lower than 14.6 the amp just gets warm now & is louder :hairtrick: u better have the batts. to back it up
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
that mojo is very sensitive to voltage.... they will blow the fuck up if your electrical system isnt top notch....
Id rock the t4KS
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Id rock the t4KS
What he says right there aint nothing but the truth!
If your making a daily beater, fosgate all the way.
But if your making a spl, or a bassracer, Id have to rock that Memphis!
The reason behind thatt is becasue you can drop that memphis down to lower ohm loads, and step your voltage up to 16 (18.5volt charging) without any problems or modding.
Either amp you run with your gonna need a decent battery bank.
If amp size is a problem, maybe you will need to look at the memphis, they are about the same length as a t4k, but they are very narrow, you could stack 2 mojos next to each other, and you would still be using the same amount of room compaired to a t4k.
