08zx400.1 Only Power On When Turn Up Volume?
Lucas702
So my buddy called me over to look at this brand new 08zx400.1 he installed because it will only turn on when he turns the volume on his deck up about 1/3 of the way. If he turns it above that, the amp will take about 5 seconds then it will click on. Once it is on, if you turn it below that volume, after about 5-10 sec it shuts back off. I checked all the connections on the back of the deck, and the battery and ground and everything looks fine. I checked the gain, x-over, and bass boost, all are fine. I checked the hi and low pass switch, and its set on low. When I switch it between the power on modes, "Audio" will give it power (only when above 1/3), and the other 2 do not give the amp power. Any suggestions? New remote wire?
Sure the remote wire isn't connected to a speaker lead?
'Audio' means 'turn the amp on when the inputs see audio'
'DC' means 'turn the amp on when the inputs see DC offset' which some OEM decks use, I think it's +6v?
'+12v' means turn on when there's 12v at the remote on terminal
When you have it on 'audio' it's expecting to see speaker level outputs from an OEM deck which is why it keeps turning off... even a decent pre-out headunit is nothing compared to speaker level signal, although I'm struggling to envision how you connected it up...
EDIT: Pretty sure the manual would have told you most of this... usually the first place I go when an amp isn't behaving.
Edited by Boon
10.x volts fo' life!
Well I thought it would be something like that.
I didn't put it in, someone else did. I pulled the deck out (Sony) and saw he had the remote wire hooked up to some blue wire, I didn't have the schematics, and hooked it up to the remote wire and bada bing bada boom it worked perfectly fine. Thanks for the help peeps
hmm weird. usally the solid blue wire from the headunit is the remote wire, then blue with white strip is power antenna, if it was hooked to that wire, the amp would only come on when the headunit was in tuner (am/fm) mode.
Aftermarket headunits all follow the same color codes for the wiring harness, weather it be sony, alpine, panasonic, eclipse, pioneer, jensen, dual, boss, yadda yadda yadda.
glad you got it figured out tho and its working :)
Edited by audiofanaticz
Well I had another sony a while before I put in my Alpine, and I was using the remote wire which on both decks is blue with a white stripe on it. I still cant figure out which one it is because I don't have manuals in front of me or anything but once ill do ill let ya know what it was.
the remote wire for the sony deck in my mom's truck is blue with a white stripe.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
  • Who's Online   1 Member, 0 Anonymous, 716 Guests (See full list)
