Wall? Musical?
Chode69
Chode? get a challenger and wall that bitch with the 4 15's ! lmao. just a suggestion :spiteful:
Or a 09 'Maro.
http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
so far switching vehicles will cost me almost double my payment for some fucked up reason....so as of right this moment i see no change in vehicle but i will be redoing my current box in the Durangho in the near future
NoFearX18 said:
trainman0978 said:
Holy Nut Butter.
My thoughts exactly :) Ill probably do the 2 18 havocs first because of money and then save up for power power and swap them out for mayhems or btls.
And why would your payment be double. Is the dakota that much more money than the durango is worth?
yea seems like this one place is tring to fuck me. charge me full price for the dakota and give me next to nothing for my durango...when the durango is easily worth more
i fuckin hate car dealerships
NoFearX18 said:
trainman0978 said:
Honestly if you're only shooting for a 150 in an extended cab truck you should be able to do 4 15's in a no wall application and do 150's all day long. There are tons of guys out on the Db Drag circuit that have 2 15's under the window line in extended cab trucks doing 150's. I believe that Alpine was doing those kind of numbers in his truck. I would honestly think that unless you're going to use the bed of the truck to store batteries and amps you won't have enough room to do a wall. Imagine trying to fit multiple batteries and amps on top of a 16+ cube wall for 4 15's. You will more than likely run out of room. Were you planning on using the bed of the truck for storage as well? If you're gung ho about walling it then do it, but I was just saying that with the power and subs that you mentioned a 150+ should be easy even in a no wall.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
walls are picky lol, if you dont know what your doing/have no box building experience i wouldnt recommend it. i know you could pull it off chode, just use lots of bracing and double baffles. try and completely seal it from the back of the truck, if you can that will eliminate the rear flexing and increase your output alot. as for using the bed of the truck for amps and batts i dont think that is entirely necessary. im not sure what kind of truck it is and didnt catch what kind of equiptment but im sure there will be room on the front baffle to mount the amps, as for battery's sum trucks are big enough to be able to fit two batts under the hood. otherwise fiberglass a center councle and house the batts under that. no need to drill into the cab and box.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
my first wall sucked, had very little output and sounded like shit. i was very afraid to do a wall in my cavy but could not fit four 15" in there otherwise. i was happy with the output, but it was a whole lot better once i added more bracing and re-tuned
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
  • Who's Online   1 Member, 0 Anonymous, 433 Guests (See full list)
