Actually there is a way to do so. You will need to find a vintage piece of equiptment made by Stiger called an Acumatch. This was something that allowed you to dial in the "dummy" impedence to get the desired load that you wanted at your amp. I never used one but back in '98 I had a sales guy at the local shop trying to sell me some to get my amps down to 1 ohm where they would put out max power. I bet that they are almost impossible to find, but if you look hard enough you may come accross one. Otherwise you can use a JL amp that puts out the same power from 1.5-4 ohms. That would be your only other choice.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Ok thanks for the help.
How are the JL slash v2's able to produce the same output at 1.5-4ohm?
I don't know what technology they use, but they do produce that kind of power at those impedences. Check em out you'll see.
1 XS Power D3100
Audio Control LC6i
Stock Deck
You can get output impedance transformers (BCAE has some info on them) but they're fairly rare and more for home/pro audio use I think. Also I imagine they're slightly inefficient in terms of power in vs power out.
With the JL amps I would guess they have some sort of current limiter on them?
10.x volts fo' life!
ZX1000.1 is the cheaper alternative to slash 1000.1....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
What are the zx amps?
Kicker
My YouTube Videos
Alpine's PDX amp's also put out the same power at 4-2ohms (not sure if 1ohm stable).
