I want to know what kind of box would be the best to build for my malibu.  I have 2 - 12" kicker 4 ohm svc and a kicker 300.1 amp thats 2 ohm stable.  I will be addind a kx3 crossover and a 400.4 amp for the kicker mids and highs.  I would like a box that allows the sound to carry into the car without having to fold down the rear seats, and would allow access to that thing gm calls a spare tire.  I have built several boxes but I want this to be the best one.  I can work with wood, mdf, fiberglass, bondoglass , etc.  I have been doing wood working fot the past 15 years and car audio for the last 12 and paint and body work for the last 15 years also. off and on.  So I know a lot but not enuff. I do know that iIwould like to port the box thru the rear deck which I plan on glassing and painting to match the car.  I also do ACAD if that helps for sending drawings if you design them that way.
Steve Meade pleas help......
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
anyone can help...not just steve...
anyways...i would say do some sort of bandpass and port thru the rear deck like u suggested. having acess to the spare tire may be the tricky part though. if u want box plans then pm ray or david...
i likes me some audio stuff...
I would say do a SIMILAR or IDENTICAL setup to what Steve did in his civic the FIRST time. He had to use the whole trunk to get those 18's in there in a ported box but w/ Kicker 12's your airspace req's will be way less so it should leave you "spare" room/access to ur plastic-donut-tire-thingy.
Check out the PRE-THEFT build of the civic.
http://www.sounddomain.com/ride/239025
Hope that helps.
If not feel free to throw more Q's out there.
Like Scratchy said-Steve is a pretty busy guy w/ 3-4 projects goin at once PLUS HIS REAL JOB, so it might take a while b4 he gets back to ya as he gets a TONN of "Hey Steve!!!" questions everyday.
GroundPounder, Ray, and few others on this site are quite knowledgable so just toss your Q out and if someone has ur info, you should have a response pretty quick. Otherwise PM Steve direct.
~2cents.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
thanks for the help.
PPI dbl din
DC Level 3
DC audio 2.0k
SHOULD I PORT THE REAR DECK OR JUST OPEN IT UP?
PPI dbl din
DC Level 3
DC audio 2.0k
The more you open it the more air/bass can get into the cabin and thus the louder/cleaner your bass will be. Steve opened his up pretty big so that even if the seats were UP the subs could still hammer thru that giant throat and bounce off the rear window. I know he left the seats down for comps but i'm sure it was damn loud even w/ the seats up. Prolly around 200in^2 in that rear deck opening. The free-er & open the better.
THIS IS MY PLAN SHOULD I PORT THE BOX CAUSE I WOULD LIKE SOME SPL AND SQ  IF I CANT HAVE BOTH I WANT SPL.....  ALSO I WANT THE SPEAKERS FACING THE REAR SEAT.  CAUSE I HAVE PLANS FOR THE REST OF THE TRUNK.  LIKE USING IT...
SPEAKER_BOX.pdf
PPI dbl din
DC Level 3
DC audio 2.0k
box looks good, properly tuned it will do very well for sq. Keep in mind that you will want it to be tuned low for music but it would need to be tuned a lot higher for spl. I would port each chamber through the rear deck.
IF I GAVE YOU THE DIMS COULD HELP ME TUNE IT FOR SPL
PPI dbl din
DC Level 3
DC audio 2.0k
Of course.
Give all the T/s parameters of the subs and over all size you have to work with. We can at least give you something to start with.
