Trim it back some, thats what I do...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Timmay showed somewhere in one of his builds a way you can do it very cleanly... in essence he soldered the tips, then ground it down with a grinder till it would fit. Looked extremely nice.
or get a distro block that excepts 1/0 on both ends and drill it out for 2/0 thats what i do if you cut the wire and stick it in the hole thats called bottle necking and defeats the purpose should have just ran 1/0 all the way through
must be nice huh
r u fuckin serious? lol. wtf do you think would allow more current to pass through. a big ass piece of metal and then longer wires coming out of it, or straight 2/0 to the amp? hmmmm
wow are you fucking retarded you fag did you read the fucking question he asked lol stfu then i do agree that 2/o straight to the amp is a better choice but wow any who your best bet would be to solder the wire and then shave it down x2 on that
must be nice huh
I have never seen a 2/0g to 1/0g wire reducer.....only 1/0g to 4g and 4g to 8g. As stated before you Solder the entire tip of 2/0 and then proceed to grind it down into a slight point just to the point where the tip is slightly smaller for easier insertion (no homo).
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
I may try out that soldering thing..I'm all about neat wiring and connections.
I have been searching and found these welding connectors. You can remove that screw and that little end piece pops out, I believe this could work, if only I can find some cheaper
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
