Looks sexy to see all those woofas in there at one time...............and why didnt you brace the tunnel of doom?
Well it's pretty heavily braced on the outside of the tunnel and there's about three gallons of fiberglass on the whole skeleton. I'm trying to avoid putting visible braces inside the tunnel for right now. That's why I'm going to test it first before continuing.
Plus these subs are about 250RMS a piece and don't do too much damage to their positions. I'm used to larger ones, but yeah I'm definitely going to be aware of that. Especially since the faces are only single thick with a coat of glass.
I'll keep an eye on it. Thanks!
Need an install? Hit me up.
[email protected]
From what I've seen from Assman and KingSuv, sometimes bracing gives it a "industrial" look, allthread or chains used, I kinda like it.
...I guess if you have to add any bracing to that tunnel, it will come down to functional strength over looks! :D
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Look good! You put down some bolt, nut, and washer to hold it steady so it don't flex. I had bracing wood in my box design and the sub tear it.
PT, you can run the internal all-thread. Stop the lengths on the inside. Drill and tap the center of the all-thread and run a SHCS and washer on the outside of the box. This would hardly be noticeable. and still give you strength...
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Heh, the terms 'inside' and 'outside' get a little confusing with this design. I think I know what you mean though. I do have a lot of that stuff at my shop at work, but I'm going to wait to see what these subs will do.
The first sign of flex, I'll jump right on your advice. I'm not bashing you guys for help with the bracing, I just want to avoid doing to many more things in the back unless I have to. It's very hard to get in there as it is and it will be a pain in the ass to make more mods...
[email protected]
Neo,
Just got home to see the new pics. Looks badass!
Is the tunnel sealed off in back with the rest of it open back there?
If the back of the box is using the rear of the car for enclosure and there is a significant amount of pressure back there, the hatch door will vibrate and flex at the bottom (where it closes) back and forth on it's rubber seal as far as the latch is going to let it move.
I ran 4 12"s sealed back there with 400w and the hatch moved more than you would expect, the rear hatch is really a weak link in a PT in termes of what subs can flex/vibrate......so I am thinking you are gonna beat up the hatch door pretty bad!
:D
Can't wait to see some vids, but take your time and set it up right, so you don't have to climb in that tunnel for any extra work.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Neo,
:D
Right now, yes. The tentative plan is like this:
-Test structure at half power
-Brace more if necessary
-Pretty up the front
-Install amps
-Test for SPL a number of ways:
-without sealing the back
-sealed back
-without rear plate
-using the top of box as port
-etc...
I'm going to try to make it as loud as possible trying all the different ways that I can.
Interesting fact, if I sealed the sides of the wall and the sides of the top of the box, the space between my ceiling and box would make for a port that tunes it to around 40hZ. Lol, but that's so lazy. I'm going to try it though. Gorilla flex doesn't bother me at all! Even if I don't hit numbers, this PT Cruiser will make for a great air mover haha :Dhttp://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif :shok:
[email protected]
Can't believe i missed this one.?Its looking good.You said you didnt want braces visible in the tunnel,if you decide to put some in there
i'd use all-thread.It is strong and holds well.
Assman Idustries
Fear The Duck
Team Notoriously Loud Mafia
