2 Ohms And 4 Ohms
BJD3
I'm looking at an amp that outputs the same RMS wattage at both 2 ohms and 4 ohms. About that I have two questions:
1. If I do end up buying it, would it be better to run at 2 ohms or 4 and,
2. Why?
Sorry for the onslaught of noobish questions, but I want to make sure I'm getting the most for my extremely limited funds.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
2. Why?
if it pushes the same power at both 2 and 4 ohms, then it has a fully regulated power supply from what I understand, and it would make no difference in what ohm load you run the amp at because as long as the amp is stable at the lower ohm load you arent doing any damage to the amp and putting it through any excess stress. Someone correct me if I am wrong in any of this.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
the jl audio slash amps do. idk any other ones off the top of my head.
Correct! as far as I know JL has the market on the RIPS aka regulated internal power supply. anywhere between 2 ande 4 ohms IIRC its going to putout the same wattage.
EDIT: IIRC its actually between 1.5 and 4 ohms.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Another question, what would the pros and cons be of running an amplifier with a regulated power supply? I understand you wouldn't be able to raise or drop the resistance to eek more power out, but besides that what problems could I run into getting an amplifier with a regulated power supply vs. one without?
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Alpine PDX's do that i'm prettty sure... They nice and small to :)
Previous: 1988 Nissan Patrol
Rockford T800.4
Rockford T1 15 (sealed)
Rockford 6.5 Components
Current: 1997 Jeep Wrangler
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
Alpine 9886 Headunit
RF P300.2
RF P500-1bd
2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz
4x Hertz HCX130's
Current comment...
Satisfied for the moment, focusing on performance upgrades
flexability basically so you dont have to worry so much about matching voice coil impedance to your amps
Scientia est Vox
  • Who's Online   1 Member, 0 Anonymous, 2176 Guests (See full list)
