ok i have a hifonics goliath currently
and i was thinkin of using it to power ten tens
specs on subwoofer
Subwoofer Size : 10" HEX
Design : Dual Voice Coil
Power Handling (RMS) : 350 Watts
Power Handling (MAX) : 700 Watts
Sensitivity : 91dB
Frequency Response : N/A
Impedance : 4-Ohms
specs on amp
1 x 1800 @ 4 OHMS, 1 x 3200 @ 2 OHMS, 1 x 5000 @ 1 OHM
i should be able to run the woofers at 2ohms....so what would the rms be then coming from the amp?...or would it be 3200 watts rms?
im currently using the goliath to power three kicker l7's at 1500 rms a piece at 1 ohms or 1.5 ..i dont remember
specs on subwoofer
Sensitivity : 91dB
Impedance : 4-Ohms
specs on amp
it'd be 3200w rms lol.
WAY WAY WAY too much for that sub.
10 10 inch subs that are 350rms are going to total 3500wrms.
If the amp is 3200wrms at 2 ohm, and you can configure the sub wiring for 2 ohms the amp will be fine.
hey you changed you're name you sneaky rabbit....
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
should be good you wouldnt even be underpowering them enough to really tell a difference
  • Who's Online   0 Members, 0 Anonymous, 2597 Guests (See full list)
