Fosgate T1's & Aq 2200d + 11cuft@29hz
Everything looks good, and a clean box build.
But you failed with the port.
Posted Image
If your port is X numbers wide, and you make a bend the port should still be X wide, not narrower or wider.
Being that its a single port that splits into 2 for each chamber of the box the width from the back wall of the box and the bent port should be half as wide as the larger single port.
It may just be the angle of the picture. however if its smaller along the back it will mess with tuning, may cause port noise, and hurt numbers.
Posted Image
thats exactly what i did^ 3" from each chamber, both then being lead to a big 6"
2 SSA Xcon 18's
Sundown 2500D
Pioneer
4 Stinger SPV35 batts
SecondSkin Audio Damp Pro
Knukonceptz Flex[/size][/b]
aight, good deal then. Its just the camera angel that makes it look narrower :)
Edit:
As for the V or a seperator in the middle, wont really effect much, not really needed, tho it help to stiffen up the box more.
As long as both subs are firing, the air pressure from chamber 1 will not blow into or effect chamber 2.
In old test boxes I have made a long time ago, for my l7s it didnt change meter scores a tad.
ye. it does look like it from the picture. but i promise its 3" to 6" :) lol
2 SSA Xcon 18's
Sundown 2500D
Pioneer
Bangin, I was thinking the exact same thing about the port as you. I looked at it and said to myself there's no way that the port wall is far enough away from the back wall of the box. It doesn't look like it is from the picture at all, but if it is that's all that matters.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
nice carpeting job man!
how did you trim the carpet on the ports cleanly? i always find it hard to trim it clean and straight
