Screws Vs Wood Glue
donsie
Are there any major benefits when using wood glue over screws while building a box? I always see people using glue so I figured there has to be some sort of advantage, considering screws seem easier to me.
chicken is basically the native american hulk, you think he broke that curb with his rim? think again, that was merely him stubbing his toe.
I use both glue, screw, and then seal with liquid nails but be sure to let the liquid nails cure before putting your sub in b/c it can deteriorate some foam surrounds.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
I use both and will only use both unless i had a nail gun for my air tank. Screws are for strength. Cant go wrong using both. Wood glue also acts as a sealant aswell but i still use caulk or glass resin in my corners so i have no leaks.
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
wood glue is always a must, it seals the box, and creates a much better joint than screws or nails alone.
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
the screws hold the wood together while the glue dries the glue holds the box not the screws
R.I.P!
(Nov-29-2009)
92 explorer
current build
Ever ripped apart a good MDF glued joint? It'll probably rip the top layer off 1 half of the MDF because the dried glue joint is actually stronger than the MDF itself.
The screws are really just there to hold it together while the glue dries... you could feasibly do a no-screws box but a no-glue box would probably suck.
Also I like the screws for providing a little bit of torsional rigidity.
10.x volts fo' life!
Titebond glue and a screw every 3-4" apart is the best!
Don’t go closer then a screw every 3" or it weakens the wood!
Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year
94 Xploder on 22s - Gutted for now...
87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue
*ROLLERZ ONLY MAFIA*
Crankin the volume knob and hittin switches.
http://www.rollerzonly.com
The screws have very little structural strength. Using too many will actually weaken the join. Use plenty and plenty of good PVA wood glue, or Polyurethane glue if you wanna spend big! You'll never break a solid glued join, screws will just tear out!
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
  • Who's Online   1 Member, 0 Anonymous, 868 Guests (See full list)
