AI James Posted December 18, 2008 Report Posted December 18, 2008 as bangin altima said id say blown VC Quote
EricM9104 Posted December 19, 2008 Report Posted December 19, 2008 Ive heard that happen when u put some subs in a sealed box with out a divider and i didn't see any port so im assuming its sealed if it was like that, assman would've blown his subs in most of his setups. :01nocomment8so: so would tommy, and other various groundpounders. Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Gotloud555 Posted December 19, 2008 Report Posted December 19, 2008 (edited) Where did you got the sub from? Something is wrong with the sub not the enclosures. Did you abuse the sub or brought it like that first time? Edited December 19, 2008 by Gotloud555 Quote
MikeJ Posted December 21, 2008 Report Posted December 21, 2008 What Amp are you running?? My SE 15's first sounded like that when I put a new US AMPS MD2D to them wired at 1 ohm, the amp was "clipping" because voltage dropped down to the 10 volt range. I added two Kinetics batteries all with 1/0 wire and the noise went away. I would check what your voltage is dropping to. Hope it helps Quote
zfrerichs Posted December 22, 2008 Report Posted December 22, 2008 What Amp are you running?? My SE 15's first sounded like that when I put a new US AMPS MD2D to them wired at 1 ohm, the amp was "clipping" because voltage dropped down to the 10 volt range. I added two Kinetics batteries all with 1/0 wire and the noise went away. I would check what your voltage is dropping to. Hope it helps x2 i had se 10s ran 1 ohm to a t1k and when the voltage would drop the subs would make the noise when my voltage was at around 14 the sound wasnt there i dont know if it was the amp clipping or not but i do know when the voltage would drop it would make the werid sound but since you took your subs out im pretty sure yours are blown Quote Roseville, CA
micb Posted December 22, 2008 Report Posted December 22, 2008 (edited) It is either: 1) A tensel lead is slapping against something (spider or cone ect) which very common. 2) Dustcap is vibrating againt the cone 3) Cone has come away from spider. 4) Coil is misalligned or damaged and scraping. Touch the dust cap does it stop? You need to take the driver out and play it free air, watch the tinsel leads if they are not making the noise then it is likely a problem with the coil i.e recone/replacement time! Edited December 22, 2008 by micb Quote My saying: "A boom a day keeps the hearing away."
Duvanator Posted December 22, 2008 Report Posted December 22, 2008 Did you make that box yourself? is it prefab? because a friend of mine had that same sound, and it was the joints on the box, they had come undone/ unglued. so it started to make that "slapping" sound once you start to turn it up. so if you free air the sub and it seems to be normal, inspect your box, and add some screws if need be. Quote head unit - Panasonic MXE CQ-C7403U amp - Cerwin-Vega EXL 1200D subs - (x2) Cerwin Vega V-MAX 15.4 box - 5.8 ^3 at 32hz spkrs- Phoenix Gold Rsd Comps
banginAltima Posted December 22, 2008 Report Posted December 22, 2008 Take the sub out of the box. Push it down evenly, if it suddenly stops are you heard a scratching sound, its a blown coil. Also, get a small flashlight and look at the voice coil to see if there is any damage. When I blew one of my T1's, 2/3 of the bottom of the voice coil actually came off of the former and fell down. When I cut the cone out of the basket, I didn't even pop the any of the coil. I guess I just melted the glue holding the coil on the former. Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
BigPimpin91 Posted December 26, 2008 Report Posted December 26, 2008 Off topic What song was that first one? /Off Topic Quote BigPimpin91's Banging Music
