I have a 200 amp alt.
isn't that the same as charging your batteries with a 200 amp charger? (hypothetically)
I'm just trying to figure out what is healthy for my charging system without causing any damage
816-591-6592
www.kcrimshop.com
Not really, A car alt. will only put out what is needed. I battery charger will put out what it is designed to put out.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
If I recall correctly, no it is not because the alternator is not supplying 200 amps at idle, so you would have to run at peak rpm to get it to put out all 200 amps. Correct me if I am wrong though
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
thats kinda what I was thinking. I need a battery charger that works the same way, or a smart charger that will shut off automatically.
I understand that. It was just a hypothetical example.
816-591-6592
www.kcrimshop.com
I am very happy with the changer, its a Schumacher model Se-75 something.
I put it on the 2 amp charge for deep cycles. It will start out around 13 volts and end at 15.2 or .3 volts. And it will maintain them nicely too.
My two G31's rest at 13.2 when finished. I charge them both at the same time, it doesn't seem to bother it none.
I am sure there are better chargers out there but are you going to notice. (I am sure someone will say yes just to say yes.)
I do box designs.
Yes, actually Gary a charger with a trickle charge option would be best. It continues to charge the batteries instead of shutting off and will keep charging them after they get to a desired point in order to give them an even higher resting voltage. I just had to say since you said someone would :D
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I do box designs.
also with a 200A alt its not like all 200A is going directly to your batteries. you have your cars computer, all the spark plugs and other electrical systems running so thats taking some of the juice away.
NoFearX18 said:
trainman0978 said:
plus you have line loss. and what your amp is sucking at the time.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
