Its called power-compression. As the coil gets hotter the impedance though the speaker increases. This impedance rise means your amp is putting out less power. You can lose over 3 dB from this effect.
I have seen cars that do better on cooler days and I have seen my truck do much better on super hot days. Some of my best scores have been in 100+ degree days.
idk in my car it sounds a lot less louder when the subs have been sitting in the cold for like a few hours and as soon as im bumping it for a while they get louder. it's like always 7-27 degress DAMN WINTER
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
I've seen the highest scores in my car when it's been 90+ degrees. The highest however came on a day where it was 70 degrees with a ton of moisture in the air. That day I happened to have new equiptment so I know that's why. I'll know more this summer when I get to meter in different temperatures.
Here's something for you. When I was in Ohio before I moved to NC I was doing a 148.1 in my car. When I moved to NC and got on a meter I only managed to do a 147.5 at best. That's a .6 db difference and I can't actually say what the variable was that changed it so much. Maybe elevation, barametric pressure, climate, who knows?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
if someone has a termlab this could easily be solved
take a small 6-10" home theatre sub, grab a big cooler and ur termalb, and a thermometer
get the cooler to 32 degrees (for ease since you can just put ice in it)
take the ice out fast and replace with the sub, meter, therm. and sit on it and burb whatever the likely peak is (prolly 50-100hz) for subs that small
now take the cooler outside, get it to 70-80 degrees, repeat test... and then we'd see a test unbiased by batteries and amp temperatures and vc temps if done fast enough
since the same tone would be used... this could also show a likely patern of whether the box's peak will change due to temperature
Edited by decafcappucino
Probably a combination of atmospheric conditions and a different meter?
10.x volts fo' life!
Yeah the meter could have been one of the varibles too. At least for a couple of tenths.
1 XS Power D3100
Audio Control LC6i
Stock Deck
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
