jizazz12 Posted January 14, 2009 Report Posted January 14, 2009 building a new box for four fosgate p312's, running two seprate amps a jl1000/1 per set. do i need to seperate each set of twelves or should i leve the interior of the box open?any opinoins would be apreciated thanks. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
jagblazer01 Posted January 14, 2009 Report Posted January 14, 2009 i would just leave it as one big chamber Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com
uhoh_45 Posted January 14, 2009 Report Posted January 14, 2009 what kind design do you have already? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
bigbodylexus Posted January 14, 2009 Report Posted January 14, 2009 I would separate them, the box would be a little harder to build but I think it would be worth it 1990 Chevy Suburban (Big Booty Judy) (4) Sundown Audio Zv5 18's (1) Sundown Audio Salt 12K (1) Sundown Audio SAX-100.4 (1) Sundown Audio SAE-50.4 (2) Crossfire ST-1 Tweeters (2) Obsidian Audio ST-1 tweeters (4) Sundown Audio Neo Pro v3 6.5's Saving 2nd Bass
uhoh_45 Posted January 14, 2009 Report Posted January 14, 2009 if your running 2 amps it would prob be easiest to do em separate instead of gain matching and shit, plus if say one sub takes a crap on you you can always continue using the other R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Airborne Posted January 14, 2009 Report Posted January 14, 2009 If it is a common chamber and one fails the box just got huge for one sub (assuming you are like most of us who can't just go out a replace a sub on a whim) and separate chambers make it easier for the monetarily challenged like my self to keep bumpin 'till the wallet(enter wife) let's me replace the quitter.
sundownz Posted January 14, 2009 Report Posted January 14, 2009 If maximum SPL is your concern dB Drag guys testing seem to indicate that common chamber is nearly always louder - but not necessarily by a large amount, in the tenths. The separate chambers do allow for the above listed advantages of still being able to play normally with one woofer - and it is also a large brace in the center of the box. - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected]
jizazz12 Posted January 14, 2009 Author Report Posted January 14, 2009 thank's for the input guy's,two it is will seperate two twleves per chamber makes sense. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
