What Causes An Exploded Battery?
You are very lucky the insides of that battery held up.
The only thing i can think of is that you drained your battery dry somehow. A dead battery can go into an internal short circuit, and that built up gas goes BOOM...
The same thing can happen with overcharging. Specifically because a shit ton of hydrogen is generated. BOOM again...
Eclipse cd7000
i sae mention of "quick charging" please define...those batteries are designed to accept a charge rate of 14-15 volts. a traditional boost box wont regulate its output and can exceed voltage quickly even at a 50amp charge rate i have seen a sears charger putting out 16 volts and at 200 amp charge have seen 18-19 volts. with kenetics you need a smart charger so it doesnt go over
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
how many of these battery's did you have and were they near each other ?
when i was around 12 years old i used to trow metal grates on top of battery's and see what happens. I know it was stupid. and they melted. almost like the pic you have.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
I had a Les Schwab battery actually explode once, as in multiple pieces. all because my voltage regulator went out and the battery got overcharged
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
Well I think you found your two batteries with the lowest ESR!
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
Been there before. Mine was from too high of voltage. Looked the same way.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
We had a battery backup in one of our remote wiring/network switch closets where the ac unit died. It got to hot in the room and we lost 2 of the batteries in the unit. They didn't look that bad but they were swelled up enough that we needed a crowbar and a couple of screwdrivers to slide those bitches out. Could there be a heat buildup where those 2 cells were mounted?
97 Maxima SE
Bunch of shit going in, check out the build
  • 3 months later...
Low voltage high amperage i blew 3 batts for my rc car from low voltage (volts go down amps go up=blown batt)
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
