Mounted In Box Vs Reverse Mounted
Guest KyleCannon
Hey Everyone,
I would like to know the difference of having a sub fire into a box versus being in a box. Also, what is the significance of having 2 subs firing out and one sub firing in? Is it due to being able to save box space because of the displacement of the sub? Thanks for the replies in advance.
i cant tell much about why, but when i took my 15's out and inverted them my peak went from 45hz to 42hz. yes i do have a t/l and did test it. it's louder deeper and just has a better sound.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
when inverse mounted, there will be more air space in the box (slightly)....and maybe a little bit of motor noise...thats all i can think of right now...
Edited by finkster
Eclipse cd7000
Guest KyleCannon
Hm, So in reality, would you guys reccomend doing reverse mounted vs regular? Any more takes on this from anyone else?
i was wondering the same thing not long ago.
i was thinking about inverting my p2's and seeing if it was any louder/lower/higher or if it had any difference at all.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
Hey Everyone,
By firing one sub inside the box and one outside it will throw the subs out of phase unless you wire one out of phase. There's really no benefit to that other than a cosmetic deal cause honestly it doesn't make sense having one in and one out. The only reason I have ever seen people do inverse mounting is for cosmetic reasons or to save .1-.2 cuft inside the box. Really .2 cubes inside the box isn't going to make that much of a difference.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
1. More box space. And you can use a box that's smaller than the sub inside, although this is only really useful for hardcore SPL applications.
2. Better cooling for the motor and coil
10.x volts fo' life!
box volume changes, causing tuning to change, causing the peak to change
So its not in ANY WAY NOR FORM bad on a Subwoofer...?
No.... unless the hole is too small and the surround rubs.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
  • Who's Online   0 Members, 0 Anonymous, 3354 Guests (See full list)
