imo bass boost should not be used at all but can be turned up a little if need be
R.I.P!
(Nov-29-2009)
92 explorer
current build
so why do amps even have bass boost if they shouldnt even really be used
for people that are under powering their subs and still want descent beat till they can afford better subs. If you are feeding your sub it's RMS power then i would leave the bass boost off.
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
Posted (edited)
i have a Fi BTL 15" on a Kicker zx2500.1 i have my bass boost always on and gain as far as it can go. when you plug the bass boost remote in on, your amp it over rides the settings on the actual amp's bass boost. so you will have control up front.
Edited by kkiiaann33
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
Everything I've seen says if you plan on using the bass boost, tune it with it all the way up so that you don't drive it into clipping when it is up. That's when you're doing it with a DMM.
I don't have any actual experience with real world tuning (still trying to learn this stuff lol) but it would seem to me that unless you plan on using the bass boost, set the gain with the bass boost all the way down.
Like I said, I'm still a n00b at this, so take what I said with a grain of salt.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
:shok:
Wow. Let us know when you cook the fuck out of that sub...
10.x volts fo' life!
was that sarcasm? or are you serious... :01nocomment8so:
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
