that looks good..so far can that car pull all of those batteries and that much wood. haha i bet that shits gonna hit somethin vicious
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
How come you don't run both 4000's. One should be enough but two would you know.....
Drew
I'm going to, but I'm waiting for it to come back from Memphis. It was acting funny so I sent it out. I was planning on strapping them because it would yield almost the same output.
EDIT: I mentioned it was a dry run. ;)
What do you do for a living....jesus... :wacko:
I work in the crude oil business. I'm a measurement specialist/terminal maintainer. Working towards the engineering side though so I'm back in school again. :rolleyes:
Need an install? Hit me up.
[email protected]
I got my car weighed and took a picture of my rear suspension. After the build I'll post before and after pics and weights of it. It's already squatting like 2". :D
[email protected]
i'd mount that little amp on the top piece but lay it down flat (hope this makes sense)
R.I.P!
(Nov-29-2009)
92 explorer
current build
If you run 2 subs to each amp it would give you less impedance rise or more power. I'm glad we can give each other advice and not get all pissy.
Drew
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
No, I hear ya! If all four amps don't fit, I'll put them up there.
Drew
That's a good point. I was planning on using both, but I didn't even think about that advantage. Thanks! And yes, I take advice well. There's no need to be disrespectful if someone's trying to help out.
[email protected]
i'm starting to not like you
3 builds in the past month and half good gear and now a TL
R.I.P!
(Nov-29-2009)
92 explorer
current build
