Two Solox 10s And A Ss10000d = 150.6 Good?
daddy_j
For what your doing, gona be tough to pick up more. Sounds like you have tested and found the loudest combination.
So your gonna add a flange piece, it may help A bit but remember it will make your port 3" longer which may change tunning.
Good Luck@!
I plan on cutting my existing port some, to make up for the aero piece. So if I add another 4" port you think that might help or hurt? I know its hard to say for sure, but whats your opinion? I wonder if I run (2) 4" ports if they would have to be longer than 4" long each. Only asking, because I could get them that short for pretty cheap, with the aero port piece.
if you have any spare wood build another 2 box's the same but use 2 4" pvc ports and then with your existing box's add the aero and see which gets louder
if the 2 ports are louder i'd say get 2 more aeros and go from there if the single ports louder go from there
alot of its trial and error see what your vehicle likes
R.I.P!
(Nov-29-2009)
92 explorer
current build
OK maybe i can help. Im still new around here but i have researched the box for my crx. Typical box is 29 x 29 x 14. You have to keep the box under 14 inches. Has to be under the windows. subs fire up and ports fire back . 4 aero ports 4 inches by 12 inches at the bottom of the back of the box. subs as far back in the box as you can get them. and try to keep the box 12 inches away from the back of the hatch. That is what is known as the CRX box.
also found this hope it helps
R.I.P!
(Nov-29-2009)
92 explorer
current build
How many people have tried this? Subd up port back? Does it work better than subs forward port back??
In a hatch .. Subs up port back > everything else IMO
Oh and yes I've tried it.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
With a CRX?
All the loudest CRXs in the world use subs forward or subs forward AND up.
10.x volts fo' life!
my car *integra hatch* seems louder with subs up port up... maybe subs forward port up, but port firing off the rear glass is louder
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Are u trying to win a comp? For what u have those numbers are respectable.
Look get rid of that amp or run it at 16V
That's probably your best change.
It's a kool amp but if u are not running 16V, I assure your not getting any where near 10k.
A better amp or a solid 16V could give you a db maybe more.
