I'm drawing a blank on the best way to run +/- wiring front front to back for a vehicle with only 2 batteries up front (1 on each side of alt)
not sure if 2 batteries would be enough but there will be 2 3000 watt amps and a ~800watt 4 channel. both batteries are powermaster d3100
thanks for the help
nothing in the back, he said he was wondering if the 2 batts would be enough... i say put a ground in the back and get another batt or 2 back there and ground them thru that then run the pos from up front to them! *but im not sure if thats effective or not but thats how i have mine
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
that should be fine, but adding another will surely help in voltage drop
I prefer atleast one battery in the rear to help with voltage lost due to resistance.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
what size alt do you have? how many alts do you have? that also helps, have you ran your power wires in 0/1 ? all that comes into play as well, im running 1 3k rms amp and a 400 rms amp to my mids and highs and i have nice voltage drop after 2~ min of heavy pounding and thats with 2 hc2400s and a hc1400 up front. look into a high output alternator and a batt for the back or 2 and you wont have any problems imo.
Team DC Audio
I'm in search for an alt now but the reason the 2 batteries are up front is because there is no room in the back for any extras, unless I put them behind the front seats. I guess that won't be a bad spot since a few of the amps will be under the back seat, but was just hoping to keep the batts hidden away somewhere.
I will probably just take a ride to the junkyard and tear one of the Jeeps apart up there to see where any others car be stuffed in the back, rather tear one of those apart first lol. thanks guys
what kind of jeep do you have? If you have a cherokee (not a grand cherokee..) then you can remove the spair tire and put one in the little space there, or on the opposite side you can cut out the plastic cubby hole into a rectangular shape and mount a battery sideways in there.
This is the cubby hole im talking about:
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
