How An Alternator Works, The Best Vid Ive Seen!
  • 3 weeks later...
  • 11 months later...
Coming from someone who has built 1000's of alternators in a factory, It would have been handy to see this back then..
As mentioned above, he used starter motor terminology talking about the alternator.. Although I've only seen his one vid so far, he could have mentioned a few pointers about variations you would see. ;)
2000 VX Holden Commodore V6
Optima D34M
The Big 3 / 4ga Hot Earth
108sqft Dynamat Extreme
120A Alt
Alpine CDA-9815
+/- 0 gauge run
2F Aerpro cap
F/R: Peerless Resolution 6" 2-way / Alpine MRP-F600
Subs: 2x 12" Kenwood KFC-W3011 in moulded f/glass 1cuft boxes / Alpine MRD-M501
  • 2 months later...
A few details were off as mentioned. I had to snicker though when he called that a Nippon-Denso. The workings were very accurate.
The regulator schematics on that part are fairly complex. A very good simple to make universal and adjustable voltage would be a ford design sold by Transpo. The part number is my screen name. :good: Two things he mentioned though that was off and need to be corrected.
A 12v alternator is NOT a good candidate for high voltage output. A few of them CAN make high voltage but starting with a 24 or 32 volt alternator will work much better.
The wattage of an alternator can be changed by replacing the stator and rotor with parts designed for higher amperage.
This was the output on a test bench of a CS144 that was rated at 120amps but now makes a little more.
The stator and regulator in this particular alternator I used for my avatar.
  • 8 months later...
  • 1 month later...
Stupid youtube banned davids farm ...
I know, it sucks, I loved his videos, watched them every day :(
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 1086 Guests (See full list)
