it'll help stop the vibration in the trunk lid itself...but it wont help around the edges where it meets the car. the rubber gasket will help a little, since it forms the seal between the two metals to stop rain, but it wont be rattle proof most likely. depends on how much power you're running of course
yes it will stop the rattle but that is all.
put the hose as far into the hole as possible, following the frame and pull the trigger.
as soon as it starts flowing thru the tube pull it out slowly leaving a solid stream of foam from the max hose length to the hole.
DONT OVER DO IT.
it will buckle your trunk lid and be visible from the outside.
i have it in my trunk lid and in the frame under my hood and have had good results, I've seen other high school students butcher it so you will get mixed reviews. do it right and you wont have problems, fuck it up and you will have a big mess
-Drew
uhoh_45 said:
When you foam up any spaces use low expansion window and door spray foam it will not buckle the sheet metal if used properly.
-Donald Hebig1989 Blazer S10 4x4-Four Fi BTL N3 15" "Ruthless bass!"-Four pair of American Bass VFL 8", 6.5", and tweets-Sundown SAZ 1500(2550wrms=156 dB) 92+ Psychlone RTA. Fully off-road capable street build. Built for music.-----------Bringing Sound Quality to a whole new level.--------------dB Drag: Personal best 161.3 sealed up and 158+ Bass Race.USACi: -Canadian SB5 Record holder-Canadian SM 4001+ Record holder
i used it before it worked great, well after i found out not to pack the hole with tipple expanding foam
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
its also very messy, tape off any areas you dont want foam to get on.
personally I would do a little bit at a time wait for it to fully cure then add to it gradually otherwise when u open your trunk you will find a nasty mess.
