philrab Posted September 7, 2014 Report Posted September 7, 2014 on torres i made a box for 4 12`s for woofer displacment i add up all 4 correct? for example my displacment is .7. im using 4 subs so do i put in 2.8 under woofer displacment Yep 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Joe X Posted September 7, 2014 Report Posted September 7, 2014 on torres i made a box for 4 12`s for woofer displacment i add up all 4 correct? for example my displacment is .7. im using 4 subs so do i put in 2.8 under woofer displacment Hope is just an example as I can't think of many 12 subs that will be over 0.2 cf.
beau123 Posted October 13, 2014 Report Posted October 13, 2014 where can i still download the program?
inm Posted October 13, 2014 Report Posted October 13, 2014 Here, I mirrored it in my Dropbox for whoever needs it. https://dl.dropboxusercontent.com/u/12084540/TorresBTC.rar On 2/28/2013 at 2:52 PM, Chaise said: "Now spread your butt cheeks so I can zap your asshole."
Edrick Flores Mendez Posted October 14, 2014 Report Posted October 14, 2014 Hey guys what happens when the program shows tou to complex to determine..but in physical port shows you your dimension and tunning shows yoyu to?
Torres Posted November 2, 2014 Author Report Posted November 2, 2014 "too complex to display" means that you don't have a standard length/width to display as a measurement. putting 24" x 18" x 22" x 45" x 11" just isn't practical to list out and expect it to be understandable.
alaskanzx5 Posted November 2, 2014 Report Posted November 2, 2014 Still like using Torres, just wanted to say thanks. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Neil Wheatley Posted November 7, 2014 Report Posted November 7, 2014 can torres be set to do a side port sub front so i can do a long straght port without having to bend it?
Jessica Posted November 7, 2014 Report Posted November 7, 2014 can torres be set to do a side port sub front so i can do a long straght port without having to bend it? You will have to switch around the dimensions to make it work. But if you are running more than one baffle it wont Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Neil Wheatley Posted November 7, 2014 Report Posted November 7, 2014 only 1 baffle it just seems that its set to have the port on the front, im trying to build a box like on the kicker l5 tech sheet but tuned lower
