OK so it appears trying to find a battery is harder then I thought. I am looking for a main battery up front to replace my stock battery. I have at the most 10"w X 8.5"d X 9"t. I have found these 4 and would like to know what you guys would recommend. Again this is only the main battery and a second one may be coming if necessary. I will be adding a HO alternating add the big three. This will be powering two SAE-1000 and a 4 channel (something around 400.4) but yet to be determined at this time. Hope this is enough info you give a good educated guess. Thanks......
1) Optima Yellow Top D34
2) XS Power D2400
3) Kinetik HC1800
4) Odyssey PC1500T
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
2) XS Power D2400
3) Kinetik HC1800
4) Odyssey PC1500T
#1 is pretty much worthless in car audio
#2 is probably the best of the four
#3 is an awesome battery and also a good choice but < #2
#4 I hear good things about, but pretty sure it doesn't compare to #2
Need an install? Hit me up.
[email protected]
X2 that powermaster is gonna be the best of the 4 IMO
Team O.B.M
'97 Tahoe
Build after the new year!!!
Kenwood kdc-x794/16gig android tablet
6 sets of Crescendo ccx65s
2 18s
2 Sundown saz 4500s
2 Sundown sax 100.4
1 Mechman SMD spec 360a
4 XS d1400s
My Feed Back
http://www.stevemead...showtopic=44841
2lc49k5.jpgub
Guest KyleCannon
I have that D2400 as my only battery and i absolutely love it! You will not be disappointed.
D2400 FTW :)
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
It's unanimus the D2400 is the choice for you.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Much appreciated responses. I was thinking along the lines of the D2400 and the HC1800. So I guess it will come down to cost, like most things do.. :good:
Haven't tested a D2400 but if its like the D2700 it would more than likely finish at the bottom in this test on spl burps. For daily I run Kinetik and have for 3 years with 0 complaints.
What are you talking about? The D2700 will stomp the shit out of the Kinetik 2400 and anything under that. The D2700 is a beast of a battery and so is the D2400. Kinetik doesn't make a battery that can touch any comparable size XS Power battery at all.
1 XS Power D3100
Audio Control LC6i
Stock Deck
opinions opinions. let's not bash the kinetik too hard, it does hold up for the price. hell i love mine and i'm sure you are very passionate about yours as i see.
Edited by dmanson
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 571 Guests (See full list)
